Posted by The tractor vet on April 17, 2012 at 20:36:23 from (75.19.127.43):
In Reply to: IH 766 TA posted by BWF on April 17, 2012 at 19:36:47:
Yea, But did you go thru the MCV and check all the valve spools and install a new MCV spring kit and set pressures ?? Did you set the end play on the Quill?? .Did you bleed the brakes?? There is a lot more to installing a T/A then just twisten some bolts and nuts. Did you put the sump check plug in ?? Did you install all new gskt's and o/rings in the MCV??
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
