If the leak is THAT bad you should be able to find it visually.
First off get the antifreeze out of there NOW. Use plain water for your testing as it is much cheaper, and if you spill it, your dog isn't going to die licking it up.
Drain the system if it's going to get cold enough to freeze, but it looks like for the next few days at least the temps will be in the low 40's at night.
Taking the plugs out and giving the engine a whirl after sitting overnight, at least one of the cylinders should shoot a stream of water out the plug hole.
Another thing you can try is to pull the oil pan off the engine and set some cardboard underneath. You should see a puddle form if it's leaking that bad.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
