Re: air blowing out gas cap vent hole on 656
Posted by Janicholson on April 18, 2012 at 06:30:01 from (199.17.6.207):
In Reply to: air blowing out gas cap vent hole on 656 posted by don656 on April 18, 2012 at 05:52:11:
I respectfully disagree with mkirsch.
The heat of operation and sun were in play, but the air had long before been fundamentally purged. The vapor pressure of fuel (todays and yesterdays inclusive) is such that the light fuel components, some of the main components of gasoline, isooctane, butane, ethanol are aromatic compounds, they will vaporize at room temperature. That is why gasoline will evaporate when placed in the open. In the winter, the temperature is low enough that only a few of them evaporate. Winter fuel is formulated with higher volitility Butane to make winter starting possible. Spring gasoline is a problem because it is quite often the winter grade and will fume excessively out the vent. It is wasted fuel in every way. Modern cars have pressure rated tanks and vapor recovery systems to avoid pollution (hydrocarbons) and wasted fuel. Jim
