Super A Belt Drive
Posted by Fixmnflym on April 18, 2012 at 07:15:53 from (184.19.87.5):
third party image
third party image
Hi Everyone. The belt drive has two places where it is sealed to keep the oil in. An O-ring seals it where the belt drive case meets the PTO case to keep the oil out of the shims, and an oil seal on the shaft. The shaft oil seal mounts in a seal retainer and rides on the spacer. The spacer goes between the outer bearing and the belt pulley. The shaft seal will keep the oil from coming out the outside of the spacer, but what will keep the oil from coming out the inside of the spacer around the shaft?
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
