I personally dislike .002 bearings. I have seen way too many installed routinely during an overhaul. The crank would be in good shape and then someone just feels it must be worn a little so puts in some .002's.s Then the next tear down all the journals have grooves in them and has to be reground for sure. Some time we forget that the cyl in lubricated with the throw off from the rods and if clearance is not correct we get too much or too little throw off. These old birds run on quite a bit of clearance and it has to be balanced so pistons get lubed properly and keep the lube system in general balanced out.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
