Re: Re: Re: super M clutch fluid
Posted by Haas on September 21, 2000 at 06:04:01 from (129.37.117.184):
In Reply to: Re: Re: super M clutch fluid posted by Pappy on September 20, 2000 at 22:11:18:
The M has a grease fitting for the pilot bearing. I assume the Super M is the same. On the M, you have to rotate the engine until the fitting which is located on the flywheel lines up with the hole in the bottom of the clutch housing.
Post A Followup
: Re: Re: Re: Re: super M clutch fluid
