Re: H Water Pump
Posted by The Red on September 21, 2000 at 08:41:49 from (206.246.187.2):
In Reply to: H Water Pump posted by Tom A. on September 21, 2000 at 07:28:15:
Tom you might have to take a file and really clean the casting just above the pulley to see the pin. It is 1/8 inch in diameter and goes in the hub at a 45 degree angle. You should beable to see the pin hole on the inside of the hub about half way down. That will help you figure where the other end is at.
Post A Followup
: Re: Re: H Water Pump
