Re: can you pump oill thru SH
Posted by Paul from MI on April 19, 2012 at 05:04:14 from (204.106.250.243):
In Reply to: can you pump oill thru SH posted by VA GAsman on April 18, 2012 at 05:08:59:
I built a pre-lube system out of an empty freon container, although anything airtight that will hold 2-3 quarts will work. put a 1/8NPT valve on the bottom & an air hose fitting on top. Run a hose from the valve to the gage port on the engine, put air in the tank to about 15psi and open the valve. Oil will flow thru all the oil galleries, bearings, etc. to lube it before starting. Takes longer to describe than to make it.
