That's for providing voltage to the starter when you press the button when trying to start the engine.
You should have an ignition switch that provides voltage to your coil. There should be a wire that feeds voltage to your ignition switch to one of the terminals on your switch. Use a volt meter or test lite to check for voltage at the switch. If there's no voltage feeding your switch you need to trace that wire back to where its getting voltage. You may have a broken wire or bad connections.
If you have voltage on that wire, put the switch in the "on position" and check for voltage on the terminal that feeds voltage to your coil. If there's voltage here and none at the coil replace that wire to the coil. Hal
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea
... [Read Article]
Latest Ad:
[More Ads]
