Re: Cub starting problems
Posted by El Toro on April 19, 2012 at 14:50:30 from (108.3.225.57):
In Reply to: Re: Cub starting problems posted by Kyrock on April 19, 2012 at 10:25:21:
When the ignition switch is in the on position and you do not have any voltage on the terminal
that feeds voltage to your coil, replace the ignition switch. Hal
PS: Run a separate wire from the + battery terminal to your coil and see if the engine will start.
