Re: Cub Block
Posted by george on September 21, 2000 at 11:02:43 from (209.9.254.221):
In Reply to: Cub Block posted by Red Raider on September 20, 2000 at 19:13:50:
Use caution if you are hoisting from any structure. Wood trusses are not typically designed to bear load on the bottom chord. This chord is in tension. Although it's only 110#, be careful when lifting. Also, a come-along and straps is not rated for lifting...the sprocket could disengage and you could be seriously injured. Better to use a floor jack or cribbing.
Post A Followup
: Re: Re: Cub Block
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
