Re: 1586 hot
Posted by El Toro on April 20, 2012 at 05:58:22 from (108.3.225.57):
In Reply to: 1586 hot posted by jim mall on April 20, 2012 at 04:51:54:
Is the bottom hose hot? If it isn't hot you probably have blockage in the tubes not allowing the coolant to circulate. Make sure you have the thermostat installed correctly or that it is opening fully. Your fins on the radiator may be plugged from dirt blocking the air flow. Hal
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
