Re: i-h scout engine running problem
Posted by Janicholson on April 20, 2012 at 06:12:35 from (199.17.6.207):
In Reply to: Re: i-h scout engine running problem posted by glennster on April 20, 2012 at 06:02:11:
With it choked the answer must be a vacuum leak. The intake manifold is a recasting of a V8 with 50% missing. The casting may have a rusted through or cracked exhaust heat riser passage, allowing dramatic EGR.
The issue would be internal. To check it the manifold must be removed. Block off the carb passage and turn it so the passages are upward. Then fill the intake with water and see if it comes out the riser passage. Jim
