Re: Changing an IH 450 axel?
Posted by D Slater on April 20, 2012 at 06:41:27 from (184.15.45.89):
In Reply to: Changing an IH 450 axel? posted by dej(jed) on April 20, 2012 at 05:41:36:
Bull gear can stay in but the bolt and heavy washer needs removed from the inside end of the axle before it will come out. Can be removed through the pto opening after removing the pto.
If lucky the axle will just slide out of the bull gear splines when axle housing is removed with axle. If not lucky axle may need pushed out of the bull gear splines. Helper would make it easier to put back in the splines.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
