Re: Re: Re: Re: Farmall M twelve volt conversion
Posted by Bob M on September 21, 2000 at 12:58:26 from (192.232.120.194):
In Reply to: Re: Re: Re: Farmall M twelve volt conversion posted by Randy Red on September 20, 2000 at 18:53:57:
Randy - An LED won't work here. The alternator needs to "see" a load of at least 200 milliamps on the #1 (lamp) terminal before it will turn on and start charging. An LED - which might draw 20 milliamps - draws way to little current to turn on the alternator.
What you CAN do however is substitute a resistor for the warning lamp. 15 ohms and 2 watts or higher rated should do it.
My experience however is the alternator warning lights seem to last forever. I've done a bunch of conversions over the past 30 years - have yet to have a warning light burn out. Nor have I ever had to replace a warning lamp in the dashboard of any vehicle I've ever owned for matter...
Post A Followup
: Re: Re: Re: Re: Re: Farmall M twelve volt conversion
