Re: Update - Farmall 140 Won't Start Discoveries Today.
Posted by mkirsch on April 20, 2012 at 05:37:34 from (64.80.110.74):
In Reply to: Update - Farmall 140 Won't Start Discoveries Today. posted by John G. Hasler on April 19, 2012 at 19:43:41:
The problem is in the GASOLINE. The gasoline is still there when you mix in diesel, and still a problem. Diesel doesn't magically turn the gasoline into something else.
You've just introduced another problem by adding something that the engine was not designed to run on.
There is nothing you can add to the gasoline that will solve the problem.
