Posted by Super-H-Mike on April 20, 2012 at 07:41:33 from (76.164.145.223):
In Reply to: 1586 hot posted by jim mall on April 20, 2012 at 04:51:54:
If it is trapped air in the system, I can tell you what I do on automotive engines...I fill it almost full, then run the engine till it just starts to get "hot", then shut it down and wait about 3-5 minutes and repeat the cycle over again. By stopping the engine, the heat has a chance to transfer around and equalise somewhat and gives the stat a chance to heat up and open. . The air will usually work itself out in the process. Can take up to 4-5 cycles on stubborn ones. After it is circulating, top it off and cap it. I also use the special air operated vacuum devices to purge systems , but this cycle method works too. Good luck to you !
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
