Re: 560 steering box
Posted by pete 23 on April 20, 2012 at 10:51:05 from (74.32.231.176):
In Reply to: 560 steering box posted by brian brooks on April 20, 2012 at 00:42:14:
Only kit ever available was a seal kit and I think that is still out there. If the splines and yoke on the input shaft are not the issue there are a couple of other minor things that come loose inside and cause the play. One is a nut on the worm shaft and other is the set screw holding worm into piston. Unit has to come apart to repair either one. Those splines strip out and then you have no steering at all. One time a customer had his hired man drive his 560 into town for repairs and when he pulled into the lot the splines let go so he had no steering. He felt pretty lucky just coming off the highway.
