Re: Starting on 6 Volts
Posted by John T on April 20, 2012 at 11:01:52 from (216.249.82.117):
In Reply to: Starting on 6 Volts posted by SadFarmall on April 20, 2012 at 03:46:14:
Unlike an H or B or C etc., I cut guys a little slack (the dudes who wanna convert to 12 which I discourage) when it comes to starting an M at 6 volts.
Similar to what Professor Jim tells ya I advise:
00 Gauge Battery n Starter n Ground Cables
The ground to a heavy clean frame member using stainless hardware or even a 00 ground cable right at/on the starter versus any thin wimpy or rusty sheet metal
Biggest heaviest highest CCA rated battery that can possibly fit
Good starter switch
Tractor tuned to perfection (especially start timing) with light or multi viscosity oil and clutch depressed and any possible mechanical loads like hydraulics OFF while cranking
Hold your mouth to the right while cranking and I found it best to sort of milk them up over on compression one piston at a time versus just holding the starter down n letting her crank n grunt till the batterys is near dead.
Thats my story n Ima stickin to it
John T
