Re: Hey Tractor Vet, is this normal?
Posted by Jon Hagen on April 20, 2012 at 17:11:44 from (69.26.23.96):
In Reply to: Hey Tractor Vet, is this normal? posted by FC Andy on April 20, 2012 at 15:23:34:
Your OK if the light goes out before the tractor attempts to move in the lowest gear.
Yes, you can adjust the trans brake too tight. Adjust it just tight enough to stop the trans gears with the pedal all the way on the floor.
For easy shifting, you need a place in the middle of the pedal travel where the trans brake is fully released before the clutch starts to engage, or it will be very difficult to shift in / out of gear.
