Re: 560 problems?
Posted by Roger Tomfohrde on April 20, 2012 at 19:11:28 from (71.49.87.105):
In Reply to: 560 problems? posted by Roger Tomfohrde on April 19, 2012 at 07:45:42:
third party image
Well I opened the cover and took a better look at the TA clutch. The disc appears new and some of the other parts look very new. The release fingers are tipped back towards the clutch disc so I think there is not enough travel to disengage the clutch. I have the spare 560 ta yet and it is not set up the same way nor does it have as thick of a clutch disc. Can I set the adjusters in so the fingers move out with it in the tractor or do I need to split it to fix this?
Also would you trade a tractor like this for a diesel that needs a clutch, I want to use this baling hay this summer.
