Posted by Lmack on April 20, 2012 at 21:41:47 from (24.131.58.167):
In Reply to: Super C disk brakes posted by BoonvilleKid on April 20, 2012 at 21:16:38:
These disk are supposed to be dry and free of oil. If the oil seal is leaking and the disk and friction surfaces are oily, it will cause the breaks to grab. First try using regular break cleaner to remove oil if you see any and that should solve the grabbing problem. You then have to find the source of the oil and get it stopped. It could be water in the trans/rear end. Check the oil level in the case by removing the plug under the operator platform on the rear right. If it is high try removing the main drain at the bottom and drain any water in the case. When oil comes out replace the plug. I would almost bet you have water in the trans/rear end. It may also be a bad oil seal. Enjoy!
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
