Re: Will a Super A 90 degree PTO fit a IH 140??
Posted by Haas on April 21, 2012 at 05:17:18 from (75.246.119.27):
In Reply to: Will a Super A 90 degree PTO fit a IH 140?? posted by Newbie22222 on April 20, 2012 at 18:19:20:
If you are getting the belt pulley PTO from a Super A to install on your 140, be sure to get the gear that goes on the tractor shaft. You will need that as well as the belt pulley unit, as if your 140 did not have the belt pulley, most likely there is just a spacer on the shaft where the gear goes. Also, the pulley drive housing uses shims and an O ring as a gasket, because the shims are needed to properly set the gear lash on the right angle drive gears.
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
