Posted by Janicholson on April 21, 2012 at 08:26:10 from (67.72.98.45):
In Reply to: voltage regulator posted by Ellis Kinney on April 21, 2012 at 08:11:03:
If the contacts are dirty, they will loose connection and the gan will stop producing output. If it were mine I would burnish those contacts with 400 grit paper, then clean them with contact spray (or alcohol on a Qtip). I would then just a very tiny amount decrease the spring tension that pulls them apart. When the tractor is off, and the contacts are pushed together, they should spark a little, then when released they should open and stay open. If the cover is put on the VR, the magnetic conditions can change, make sure the contacts open with the cover on. THis can be checked by having someone start the tractor, get it charging, then shut off the engine while watching the amp gauge. It should go back to zero just after the engine stops. If not, the gen will be subject to burning up and discharging the battery. This is the cutout relay job of the VR. Be very careful not to decrease the tension too much. The adjustment is usually a metal tab or a screw on a metal tab that anchors the spring. If it gets no better, get a new one. Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
