Re: 806 pto won't disengage
Posted by Ron 1456 on April 21, 2012 at 15:07:29 from (209.222.189.13):
In Reply to: 806 pto won't disengage posted by CompleteLawnCare on April 21, 2012 at 12:54:47:
Check a the actuator valve on the pto to make sure that there isn't dirt keeping the shaft from going all the way in. If it has a rubber boot covering the top of the valve take it off and throw it away. Dirt gets in the boot and keep the shaft from going all the way in. If you let the pto keep running due to dirt under the boot it will wear out the discs due to partial engagement.
