GordoSD has it right but I would also suggest doing a "fit check" with the disc hooked to the tractor and using some string or other flexible material to make sure they are long enough for the sharpest turns in both directions you can make without stretching the hoses. I would also add a little more in case you want to use the disc on a different tractor later which would require additional length. I have a single extra coil on my hoses which would extend about three additional feet if needed to be used on a different tractor. It is certainly less expensive to buy a couple or three extra feet now then new hoses later, Hal.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
