Re: Super C not starting Update
Posted by Andrew Z on April 22, 2012 at 05:52:05 from (64.252.147.44):
In Reply to: Super C not starting Update posted by I luv farmalls on April 21, 2012 at 19:02:03:
The starter could have been pulling to much from the starter, and thus not having enough power to the coil. Happens pretty often if you start enough semi dead tractors.
Andrew
