Re: Super C not starting Update
Posted by Brownie 450 on April 22, 2012 at 06:01:46 from (66.43.241.198):
In Reply to: Super C not starting Update posted by I luv farmalls on April 21, 2012 at 19:02:03:
Look for a terminal that has rust & isn't making good contact. Check ALL wire ends by pulling on the wire to locate any problem connections.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
