Re: Super C not starting Update
Posted by farmallhal on April 22, 2012 at 07:10:16 from (76.4.178.207):
In Reply to: Super C not starting Update posted by I luv farmalls on April 21, 2012 at 19:02:03:
I'm with Andrew on this - I've had my share of won't start tractors (from lack of starting and use) and have found what appears to be good batteries are usually just enough on the low side (usually around 6.1 or 12.1 volts or so) and the tractor won't start. Hit is with a charger for a short time and get that voltage up a little and then they usually fire right off. Give that a good try before tearing into stuff that is most likely just fine. Hope this helps, Hal.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
