Posted by CNKS on April 22, 2012 at 07:37:31 from (216.144.104.128):
In Reply to: three point on an H posted by sgtbull on April 21, 2012 at 20:44:40:
Saginaw is fine, you can keep the original drawbar. I have one on a Super H. It has 2 cylinders that you can tee together on one outlet. If you have to have down pressure, you can use the IH "Christmas tree" or add a valve. You do not have to have draft control, You can lower it and then bump it up some if you don't like the depth. I grew up with an H, pulling a semi mount plow and using front and rear cultivators -- you simply have to learn to use the hydraulics. You can put collars on the cylinders also. I simply do not think draft control is a big deal. I would NEVER consider getting rid of an H for an 8N. I did considerable work close cultivating vegetables with the rear mount cultivator, no comparison to an H with a front mount. Yes the 3 point works better, but that is the ONLY advantage to the 8N, and also the only reason they are still around.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
