Re: fine thread bolts
Posted by John G. Hasler on April 22, 2012 at 08:36:29 from (174.124.48.166):
In Reply to: Re: fine thread bolts posted by Janicholson on April 22, 2012 at 07:46:02:
> Which bolt would you trust more to hold your
> bungy jumping anchor? The first is bolted
> through a 6"X4" heavy walled tube in the 6"
> direction and through a forged steel bracket
> that pulled straight (axially) on it, tightened > (stretched)to 75% of yield. or one that was
> identical and tightened to 5% of yield.
The first one, of course. The second is going to loosen up, fall off, and kill somebody. You can't do much worse than combine an under-torqued bolt with a cycling load.
(Yes, I realize that the tube will compress a bit. The engineer who designed the joint will have taken that into consideration. He will also have allowed a safety margin of at least 10.)
Today's Featured Article - Two-Brush Generators - by Chris Pratt. Whether for product liability or because the aftermarket parts and labor business is lucrative, this concept is disturbingly prevalent. Fortunately when you step into your shop and make that jump 50 years back in time to work with your old tractor, this concept goes out the window. Even so, when it comes to the charging system, people quickly revert to this idea and start replacing the major components one at a time until it works. The reason you don't find any decals in your replacement set wit ... [Read Article]
