Posted by farmallhal on April 22, 2012 at 11:10:51 from (76.4.178.207):
In Reply to: Re: fine thread bolts posted by Janicholson on April 22, 2012 at 10:46:21:
Jim, The engine on the United DC-10 had a fuse pin failure as I recall. The bolt just was to hold the fuse pin in place and wasn't a real load bearing component. The fuse pin is a cylinderial machined piece which held the engine strut or plyon through it's mount to the fittings on the lower wing structure and the bolt was only something probably less then a .500 inch diameter merely to keep the fuse pin in place. Those engine attachments were usually line bored on installation with the straightness and hole size tolerence of something like +.0005/-.0000 while the fuse pin was probably super cooled in liquid nitrogen at installation - assuring a very precise fit. There are also very close limits on the amount of pre-load at installation that can be applied through wing deflection to permit strut to wing installation. I didn't work on the McDonnell Douglas products but know their installations were very similiar to those we used at Boeing back in my pre-retirement life, Hal.
Today's Featured Article - Two-Brush Generators - by Chris Pratt. Whether for product liability or because the aftermarket parts and labor business is lucrative, this concept is disturbingly prevalent. Fortunately when you step into your shop and make that jump 50 years back in time to work with your old tractor, this concept goes out the window. Even so, when it comes to the charging system, people quickly revert to this idea and start replacing the major components one at a time until it works. The reason you don't find any decals in your replacement set wit
... [Read Article]
Latest Ad:
[More Ads]
