Re: Farmall 450 Gas back hydraulic questions
Posted by D Slater on April 22, 2012 at 14:32:48 from (184.15.45.89):
In Reply to: Farmall 450 Gas back hydraulic questions posted by Tony_Idaho on April 22, 2012 at 08:59:15:
If hoses are installed at the end of the steel lines bolted to the side of the battery box, and a check valve block is bolted to the block on the end of the steel lines its bypassing in the cylinder or the check valve is leaking through. Or a line leak.
Hose on right side of the cylinder goes to the top hole check valve block and the other hose goes in the steel line end block, bottom hole.
Also is the cylinder hooked up to raise when the control handle is pushed forward?
Not sure what you mean on the drop, but think you mean the leak off rate. If other problem control valve needs set to double acting with the check valve and lines hooked the way IH intended.
