Re: 1939 H
Posted by athol carr on April 22, 2012 at 18:11:47 from (115.188.3.223):
In Reply to: Re: 1939 H posted by oldiron29 on April 22, 2012 at 14:04:39:
Were the F-20 rim on the tractor originally or fitted later? The early Farmall were on steel but rubber tyres were always an option. The very early Farmalls H and H had 36 inch split rims. The 38 inch drop-centre rims came later. The early W-4 and W-6 had 24 inch split rims (again the standard was steel wheels) and later the W-4 went to 26 inch drop-centre rims
