Re: 800 planter
Posted by RPM1941 on April 22, 2012 at 19:44:42 from (173.24.196.59):
In Reply to: 800 planter posted by datkfarm on April 22, 2012 at 15:17:49:
This planter has to be getting some age, if the other posts advice dont help check with soapy water on tank lid, firewall seal, hopper half seams for air leaks, it will cause bubbles, also the fan impeller shaft has 2 sealed bearings that may be dry or lube poorly, replace them. They started making them about early 80s, the 900 series came out in 1987. If the airleaks show up reseal with tube silicone. Also check the speed of IPTO, clutch discs in pto on IH tractors will trip you up also. Good luck
