Re: McCormick H magneto setting
Posted by Janicholson on April 23, 2012 at 06:50:50 from (199.17.6.207):
In Reply to: McCormick H magneto setting posted by al Carey on April 23, 2012 at 06:08:57:
That number is off by a decimal point. It is .013" The mag needs to be set to #1 at TDC so the rotor can be replaced in correct timing, it is geared to the breaker cam! It can be set with it on the tractor, but must be taken apart beyond the cap to get to the points. Jim
