Re: Buying a Farmall 706 gas
Posted by Janicholson on April 23, 2012 at 14:03:10 from (199.17.6.207):
In Reply to: Buying a Farmall 706 gas posted by P T Farmer on April 23, 2012 at 12:11:54:
Check the TA by starting in road gear TA with the throttle almost wide open, let out the clutch like you were merging into traffic, when it is about as fast as it will go in TA, shift to Direct by rapidly (which is the only proper way) moving the TA lever to Direct, forward. Be careful it will go fast. You do not need to go full speed. If it holds the TA at first and shifts to direct well, it is a pretty good indication that it is OK. Jim
