800 planter follow up
Posted by datkfarm on April 23, 2012 at 17:04:21 from (208.73.61.10):
The PTO pump PSI was measured with a gauge in line and held 1600 with the needle by pass closed and spiked to 2000 PSI so pump looks good. Found some air leakage around drum but looks like I need to put a new seal on drum or a new/used drum. Blower motor is leaking oil from the stem but not bad.
Thanks for all the help and ideas so were down to 2 things either the blower motor or the drum.
