Re: Tight and Sticky Clutch
Posted by Bob M on April 23, 2012 at 17:12:54 from (74.67.185.144):
In Reply to: Tight and Sticky Clutch posted by nyvines on April 23, 2012 at 16:53:30:
First thing I'd do is peek inside the clutch housing. For a tractor that's sat that long there's a good chance critters have been inside and filled the clutch housing with "stuff". (I've found clutch housings packed absolutely solid with walnuts, acorns, seed corn, sunflower seeds, etc. which then binds the clutch mechanism.)
Remove the clutch hand hole cover (bottom of the clutch housing) and do an quick inspection.
I presume from your handle you are in the Finger Lakes region???
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
