Re: 350 Utility power steering problem
Posted by Randy L2 on April 23, 2012 at 20:55:32 from (207.119.156.119):
In Reply to: Re: 350 Utility power steering problem posted by Janicholson on April 17, 2012 at 15:11:48:
Jim, you are dead on. The orfice screen has a hole in it and the orfice had a small piece of rock blocking the opening. I will order a new one and I hope that will take care of the problem. One question though, does the plug on the side of the steering column supposed to have a hole in it or should it be solid?
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
