Posted by DeanOlson on April 24, 2012 at 01:52:08 from (98.196.66.64):
In Reply to: timing posted by paul vroman on April 23, 2012 at 19:58:58:
I set at TDC and then get it running.
Advance distributor till it runs rough, take note of that position, turn opposite direction till it runs rough, take note of that position, go back to the middle of those two positions and tighten the set screws up.
I used a lead pencil to mark places on distributor. I do this at idle and again at WOT.
It's not too scientific but it is the way I was taught back in the day.
You may have to tweak it depending on how it runs under a heavy load. Having said that I have rarely had to redo it.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
