Re: Towing one tractor with another
Posted by tractor300 on April 24, 2012 at 14:08:18 from (74.36.163.96):
In Reply to: Towing one tractor with another posted by Zachary Hoyt on April 24, 2012 at 10:20:49:
Dad built one year's ago out of square tubing that was basically a long A frame that attached to an extended front hitch plate. A heavy tubing was welded to the hitch plate and a bolt was run through the tubing and the A frame. You could remove the pin and frame and still use the front hitch. Simple to build and easy to use. Pulled many H's and M's without any problems. However, never pulled much faster than regular tractor speed
