Posted by Hugh McKinney on April 25, 2012 at 06:00:54 from (69.147.156.34):
In Reply to: farmall M posted by geezer in mo on April 25, 2012 at 04:27:43:
Sounds like a vacuum leak. One way to check for a vacuum leak is to obtain a propane torch (but don"t light it!) and open the valve, and while your engine is missing, move the orifice around the area of your gaskets/fittings on your intake manifold and carburetor. If you notice that it ceases to miss while the propane source is near a particular spot, then you have probably found your leak. Btw, vacuum leaks are worst when at part-throttle. Full-throttle operation lowers vacuum below the throttle butterfly valve, and makes the mixture return closer to normal. Just sayin".
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
