Other then the basic engine Nothing else will work. The only difference in 460 rear ends is that the early 460's had 2 1/2 inch axles and the later ones had 2 3/4 inch axles and this was only on the outside part . They would break axles when a mounted picker was mounted . If ya want to make a puller and only a puller then go find a C301 combine engine and use the ft. cover from the 460 and rear engine plate from the 460 and the 460 flywheel and have a pressure plate made for pulling with heavier springs as the smaller 10 1/2 inch clutch will slip if ya make any kind of power . You can make good power with vary little work on a shoestring budget . Myself i would not be afraid of the 2 1/2 axles for pulling even up to 8500 lbs. The hard part with 2 1/2 inch axles is finding a set of 9 bolt hubs as when you find the 2 1/2 inch part ya have to machine a key way.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
