Re: 6 Volt Pos To 6 Volt Neg
Posted by Harold H on April 25, 2012 at 08:38:37 from (69.246.129.26):
In Reply to: 6 Volt Pos To 6 Volt Neg posted by nyvines on April 25, 2012 at 06:13:41:
At 6 volts, I would recommend having it as built, 6 volt positive ground. There is no advantage to changing it to 6 volt negative ground. If you make it 12 volt, then go 12 volt negative ground. #4 cables are ok for 12 volt but are not big enough for 6 volt.
Harold H
