Re: 6 Volt Pos To 6 Volt Neg
Posted by JRSutton on April 25, 2012 at 16:41:48 from (75.130.109.233):
In Reply to: 6 Volt Pos To 6 Volt Neg posted by nyvines on April 25, 2012 at 06:13:41:
Why change the ground??
As for the battery cable, the answer is no.
For the higher voltage (12v) there's less current flowing to the starter, so you don't need a very heavy a battery cable.
For a 6 volt battery, there's more current so you want the heaviest battery cable you can get on there to keep from restricting the flow.
It would probably work just fine while all your connections are fresh and clean, but over time you'd eventually be sorry you used a lighter guage cable.
