Check the specific gravity in your battery cells. Put a voltmeter across your battery terminal with the tractor running at half throttle and high idle. Does your ammeter ever show a charge (needle on the + side) ?
The specific gravity of the cells should be within 50 points of each other (25 is better). At half throttle you should see something like 6.5+ volts, at WOT 7.5V. Ammeter should show a charge as soon as you are off low idle.
If your ammeter shows a discharge with the tractor off, you might have a bad voltage regulator.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
