Re: Super C oil filter question ?
Posted by MJD on April 25, 2012 at 17:46:29 from (166.250.163.95):
In Reply to: Super C oil filter question ? posted by MJD on April 24, 2012 at 21:25:32:
Thank you fellas. I do recall finding that out
on a 350 tractor years ago....the old ring was way down in, and like it had actually 2 rubber rings in there. I have a dental pick or 2 and
will try to find out if there is some junk in that groove. I usually get them loose by taking my time, I just never suspected this filter would have 2 rings in it as I did get the one
out without breaking it. I will check at a later
time though, as it is working fine as is right
now. Thanks for the comments .........
mjd
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
