Re: Loose Steering on Farmall M
Posted by The Red on September 22, 2000 at 07:43:40 from (206.246.187.2):
In Reply to: Loose Steering on Farmall M posted by Lance on September 22, 2000 at 07:35:55:
Lance pull the big nut in front on the upper bolster and check the ball bearing assembly. The shaft should not have any horizontal play in that bearing. If it is OK, just loosen up the two collars at the steering post, pull the steering shaft towards you and retighten the collars. Also check the universal joint where the two steering shafts connect.
Post A Followup
: Re: Re: Loose Steering on Farmall M
