Remove the sparkplug near the radiator and bring that piston to TDC on the compression stroke. Hold your thumb over the plug hole while a helper slowly cranks the engine until you feel pressure. Once you feel pressure drop a long plastic straw on top of the piston then you watch the straw rise while the helper cranks the engine. When the straw quits rising the No1 piston should be at TDC on the compression stroke and the timing marks should be aligned with the pointer. The rotor should also be pointing to the No1 plug tower. Hal
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
